Editing hardscape objects
There are several different ways of editing hardscape objects, depending on the type of hardscape and the desired outcome.
Modification |
Description |
Editing the hardscape properties |
Reshaping the hardscape or path |
Aligning hardscapes with surrounding geometry |
Modifying an aligned surface type |
Editing aligned hardscapes or modifiers with surface modifiers |
Converting a hardscape configuration |
Editing hardscape fills and joint patterns |
Modifying hardscape tag appearance |
Creating a section view of a hardscape |
